20 years agoPCI 3.3V IO
I was wondering if anyone has connected an FPGA and a PCI/Mini-pci Card with the IO standard set as 3.3V LVTTL instead of 3.3 PCI? PCI is still a 3.3V standard, but I'm not sure if the drivers ar...
20 years ago --- Quote Start --- originally posted by stonie@Jun 13 2006, 04:54 PM did you use external components within the pci lines - as resistors to limit current or external clamping-diodes?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16149)
--- quote end ---
--- Quote End --- I use minimum current strength for most pins, including onboard ddr sdram and others. I didn't use series resisters or clamping diodes.
