15 years ago
Parallel Flash memory access failed
I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. Here are some more details :
HARDWARE :
- I use Quartus 11.0 toolkit.
- the board is designed by me. The FPGA owns a NIOSII/e system with a tristate bridge and the CFI flash memory interface. Nothing else.
- I checked the FPGA/memory connections, power supply etc ... => all OK
- Nothing special during synthesys process, everything looks good.
SOFTWARE :
- I built a hello world project with Eclipse rev Helios Service Release 1
Build id: 20100917-0705.
- I launch my soft with NiosII shell window using this command :
bash-3.1$ nios2-download -g hello.elf && nios2-terminal
- I get this answer :
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 29KB in 0.4s (72.5KB/s)
Verifying 00001020 ( 0%)
Verify failed between address 0x1020 and 0x122B
Leaving target processor paused
bash-3.1$
I think that the board has no problem (I tested each electrical connection between the FPGA and the flash). I tryed the same software with internal memory and it worked. There is a problem with the flash but I don't know where (SOPC system ? Compiler options ? ...)
Please could anybody help me to anderstand ?
Cyril
