15 years agoParallel Flash memory access failed
Hello, I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. H...
15 years ago --- Quote Start --- Hi Neptunus, Actually, the flash device was dead. That was the root cause of my problem. --- Quote End --- Hi Cyril, How did you end up programming your flash memory after you replaced the chip? Did you use the Flash Programmer that comes with Eclipse, or another method? Thanks.
