15 years agoParallel Flash memory access failed
Hello, I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. H...
15 years agoHello cyrill.garric,
I have the same problem. But only with quartus 10.1SP1. I used timing setup: 100ns wait 200ns hold 100ns. No good result:
Using cable "USB-Blaster ", device 1, instance 0x00
Resetting and pausing target processor: OK
No CFI table found at address 0x00000000
Original contents (after writing 0xF0 and 0xFF to address 0x00000000):
0: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
10: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
20: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
30: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
40: A8 09 00 04 A8 09 00 04 A8 09 00 04 A8 09 00 04 ................
Contents after writing 0x98 to address 0x000000AA:
Same after writing 0x0098 to address 0x00000154:
Same after writing 0x00000098 to address 0x000002A8:
Same after writing 0x98 to address 0x00000055:
Same after writing 0x0098 to address 0x000000AA:
Same after writing 0x00000098 to address 0x00000154:
Same after writing 0x98 to address 0x00000154:
Same after writing 0x0098 to address 0x000002A8:
Same after writing 0x00000098 to address 0x00000550:
Ignored possible autoselect code A8-A8 as no override data
present in section
Ignored possible autoselect code 09A8-09A8 as no override data
present in section
Leaving target processor paused
What timing to you use? And is it working now? Thanks
