15 years agoParallel Flash memory access failed
Hello, I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. H...
15 years agoOk, I understand.
I just tried to add embeded RAM memory in SOPC. The pb is the same... I compared my design with a tutorial issued from DE1 Altera dev board. They use a 8bit data bus for their flash memory. But the components used in both SOPC designs are likely the same : NIOSII/e, tristated bridge, flash memory interface. But the flash interface versions looks different ... Can't CFI module program an external // flash memory ?? Do I need to use another specific tool to download my program in the flash device ? Thank you for your help !
