15 years agoParallel Flash memory access failed
Hello, I am designing a simple system with a 4CE40 and a Spansion flash memory (S29GL512 : 64MB in 16bits organisation). But when I make a "hello world" software, it fails at "checking" step. H...
15 years agoFlash memory is effectively read-only memory that can be written to by very specific bus cycle sequences.
The memory datasheet will tell you how to write to it, and you might find some standard software that can do it. I'm also not sure how easy it is to perform the desired cycles through the normal bus width adapter that gets added between the 32bit Avalon bus and a 16bit memory. You can execute code from the flash (and have the cpu's reset vector addressing it), but you'll need other memory for data and stack and for the code running while you do the flash erases and writes.
