20 years ago
nothing out to uart,help me
hi,Hippo
you have to select nios serial in kernel config
CODE
[*] Nios serial support
[*] Support for console on Nios UART
I have select it ,but still it does not work foe me.why?
have you checked my ptf? I do not know whether there is some mistake.
    There are also a long pause between the message "Uncompressing Linux..." and "Ok, booting the kernel.", about half a minute.
    Was this ok? My system run at 50Mhz(input is 25MHz).
    In the menuconfig I only change the
    1 Device Drivers ---> Character devices ---> Serial drivers --->
    disable the JTAG UART option and enable UART option
    2 Processor type and features-->(0x00500000) Link address offset for booting
    3 Processor type and features--> I choose the Altera Cyclone Board
    my sdram is at 0x0 and the size is 8MByte (16Bit width)
    --- Quote Start ---
    originally posted by scut_ak@Apr 27 2006, 07:59 PM
    there are also a long pause between the message "uncompressing linux..." and "ok, booting the kernel.", about half a minute.
    was this ok? my system run at 50mhz(input is 25mhz).
    in the menuconfig i only change the
    1 device drivers ---> character devices ---> serial drivers --->
    disable the jtag uart option and enable uart option
    2 processor type and features-->(0x00500000) link address offset for booting
    3 processor type and features--> i choose the altera cyclone board
    my sdram is at 0x0 and the size is 8mbyte (16bit width)
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14751)
    --- quote end ---
    --- Quote End ---
    1. you should have
    2. boot link offset is correct
    3. no need to change, because you are using a custom board.
    You are using "tiny core", without icache and dcache. without hw mul.
    It is very slow. It takes about 7-10 clocks for each instruction.
    You should use "small" or "fast" core, with at least 512Byte icache. dcache is optional.
    Hw mul is recommanded.
    If you don&#39;t use hw mul, you have to do
    1. enable multilib in toolchain option of buildroot menuconfig
    2. add "-mno-hw-mul" cflags to busybox menuconfig
    3. processor --> Nios II Hardware Multiply Support (None) to kernel config
    From your result, the zImage loader is working. and uart direct io is working.
    The problem maybe in hw mul .
    Hi, Hippo
    here is the output from my uart(115200), then It come to a stop here,why?
    Uncompressing Linux... Ok, booting the kernel.
    Linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 2 Thu Apr 27 21:20:29 CST 2006
    uClinux/Nios II
    Altera Nios II support © 2004 Microtronix Datacom Ltd.
    Built 1 zonelists
    Kernel command line:
    PID hash table entries: 64 (order: 6, 1024 bytes)
    i compare it with yours, and find it is a little different with yours
    yours are
    PID hash table entries: 512 (order: 9, 8192 bytes)
    why? Have I make some other mistakes?
    --- Quote Start ---
    originally posted by scut_ak@Apr 27 2006, 09:51 PM
    hi, hippo
    here is the output from my uart(115200), then it come to a stop here,why?
    uncompressing linux... ok, booting the kernel.
    linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 2 thu apr 27 21:20:29 cst 2006
    uclinux/nios ii
    altera nios ii support © 2004 microtronix datacom ltd.
    built 1 zonelists
    kernel command line:
    pid hash table entries: 64 (order: 6, 1024 bytes)
    yours are
    pid hash table entries: 512 (order: 9, 8192 bytes)
    why? have i make some other mistakes?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14758)
    --- quote end ---
    --- Quote End ---
    It sould not be a problem. I have 64MB on board, while you have only 8MB.
    It may take some time to uncompress the initramfs.
    Did you use small core ? turn on icache and hw mul ?
    You may have to trace and debug linux-2.6.x/init/main.c .
    Hi,Hippo
    I use nios IDE to build my linux image, I disable the mul and jatg-uart
    then the output is the same as I build the image in linux environment
    The output is as follow:
    Linux version 2.6.11-uc0 (Administrator@MICROSOF-0DA828) (gcc version 3.4.1 (Altera Nios II 5.1 b73))# 1 Thu Apr 27 23:04:07 2006
    uClinux/Nios II
    Built 1 zonelists
    Kernel command line: root=/dev/mtdblock0 ro
    why?
    --- Quote Start ---
    originally posted by scut_ak@Apr 27 2006, 11:33 PM
    hi,hippo
    i use nios ide to build my linux image, i disable the mul and jatg-uart
    then the output is the same as i build the image in linux environment
    the output is as follow:
    linux version 2.6.11-uc0 (administrator@microsof-0da828) (gcc version 3.4.1 (altera nios ii 5.1 b73))# 1 thu apr 27 23:04:07 2006
    uclinux/nios ii
    built 1 zonelists
    kernel command line: root=/dev/mtdblock0 ro
    why?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14767)
    --- quote end ---
    --- Quote End ---
    You should check your sdram clock timing. Simple sdram test program may not detect the problem. Many people have problems on the sdram clock. Search the forum.
    --- Quote Start ---
    hi,hippo
    uclinux/nios ii
    built 1 zonelists
    why?
    --- quote end ---
    --- Quote End ---
    I think this is the problem. (I made the same mistake before, too)
    You are using nios2 v4.2, and the execption address, ie, interrupt entry, is in onchip memory.
    Nios2 uClinux assume interrupt entry at program memory, ie, sdram.
    So when interrupt came, and it stuck.
    You should update to nios2 v5.1 and quartus2 v5.1 sp2.
    Setup the execption address, to sdram.
    Hi,Hippo
    Thank you for your help, I have solved my problem now and successfully ported the uclinux to my Cyclone Board.
    Thank you for advice and your courage which guide me to my final success.,and also respect you for your excellent work done for all of us here.
