20 years agonothing out to uart,help me
hi,Hippo you have to select nios serial in kernel config CODE [*] Nios serial support [*] Support for console on Nios UART I have select it ,but still it do...
20 years ago --- Quote Start --- originally posted by scut_ak@Apr 27 2006, 11:33 PM hi,hippo
i use nios ide to build my linux image, i disable the mul and jatg-uart
then the output is the same as i build the image in linux environment
the output is as follow:
linux version 2.6.11-uc0 (administrator@microsof-0da828) (gcc version 3.4.1 (altera nios ii 5.1 b73))# 1 thu apr 27 23:04:07 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line: root=/dev/mtdblock0 ro
pid hash table entries: 64 (order: 6, 1024 bytes)
why?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14767)
--- quote end ---
--- Quote End --- You should check your sdram clock timing. Simple sdram test program may not detect the problem. Many people have problems on the sdram clock. Search the forum.
