20 years agonothing out to uart,help me
hi,Hippo you have to select nios serial in kernel config CODE [*] Nios serial support [*] Support for console on Nios UART I have select it ,but still it do...
20 years ago --- Quote Start --- originally posted by scut_ak@Apr 27 2006, 09:51 PM hi, hippo
here is the output from my uart(115200), then it come to a stop here,why?
uncompressing linux... ok, booting the kernel.
linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 2 thu apr 27 21:20:29 cst 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 64 (order: 6, 1024 bytes)
i compare it with yours, and find it is a little different with yours
yours are
pid hash table entries: 512 (order: 9, 8192 bytes)
why? have i make some other mistakes?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14758)
--- quote end ---
--- Quote End --- It sould not be a problem. I have 64MB on board, while you have only 8MB. It may take some time to uncompress the initramfs. Did you use small core ? turn on icache and hw mul ? You may have to trace and debug linux-2.6.x/init/main.c .
