anonimcs
Contributor
2 years agoNios2 Helloworld project Memory Overflow
Hi guys, I'm pretty new to Intel's environment for FPGA development and I need to use the Nios2 core for one of my designs. The design is implemented on MAX10 and I'm using Quartus 21.1 Standard edi...
EBERLAZARE_I_Intel
2 years agoHi,
Yea, you should not edit the addresses in the BSP linker script.
You may try to increase your OCRAM IP size , in the Platform Designer and re-generate your HDL. And check again with the new .sopcinfo.
You should see in the BSP linker script that your OCRAM size have increase and generate your BSP and build your project again.
