NIOS V/m dbg_reset_out signal (Q25.1 Std, MAX10)
I have a problem with loading elf file.
Signal dbg_reset_out (used for resetting HDL components) is inactive (low) when I'm using "niosv-download -r -g exeFile.elf" command (Q25.1 Std, v25.2.1 Ashling GDB Server, Linux OS, MAX10 device, NIOS V variant m).
The same command for Q24.1 Std (previous version of Ashling GDB Server, the same OS and PC) works.
For me temporary solution is using additional option -o (OpenOCD instead of Ashling® RiscFree GDB Server). Is there any better solution?
Hi pp123
For me temporary solution is using additional option -o (OpenOCD instead of Ashling® RiscFree GDB Server).LiangYuG_Altera wrote:
Please continue using OpenOCD.
We have reported this failure to Ashling for investigation.Ashling have responded to us, and fix their latest Ashling GDBServer in the upcoming RiscFree IDE v26.1.1-C in Quartus Prime Pro 26.1.1. Since you are using Quartus Prime Standard, you will need to wait for the Quartus Prime Standard 26.1 for the working Ashling GDBServer.
Liang Yu
- LiangYuG_Altera
Contributor
Hi pp123
Liang Yu- pp123
Thanks for the information.
- BoonBengT_Altera
Moderator
Dear pp123 ,
I'm glad that your issue is resolved. We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
- LiangYuG_Altera
Contributor
Thanks pp123
pp123 wrote:
Yes, of course - dbg_reset_out output connected (indirectly) with reset input. It casued probably debug module reset and (sometimes) stranged behaviour.
"Sometimes" because using niosv-download -r -g (Q24.1 Std) at Linux PC seems worked without problems.Oh ya, that is a thing to beware of.
Resetting the debug module during "niosv-download" -r can cause un-deterministic behaviour.
In your words, "sometimes strange behaviour".It is mentioned here. But we should rewrite it more explicitly for future readers.
pp123 wrote:
This connection also worked properly in our older projects using NIOS2.
The NIOS2 Debug Module is different from RISC-V Debug Module.
We aimed to make them as similar as possible at the top-level. But there are slight difference between them.You may refer here for migration tips from NIOS2 to NIOSV.
(Rewrite this more explicitly too)Regards,
Liang Yu - pp123
Would you mind sharing what is the incorrect reset connection?
This connection also worked properly in our older projects using NIOS2. - LiangYuG_Altera
Contributor
Hi pp123
pp123 wrote:
it seems that the problem with reset & halt was my incorrect reset connection.
If possible, we would like to improve our documentation to warn other dbg_reset_out user.pp123 wrote:
So I only wait for Ashling's fix (GDB server).
Got it, I will let you know once it is ready.
Liang Yu - pp123
I am sorry. It is interesting that I haven't noticed problems using Q24.1 Std.
So I only wait for Ashling's fix (GDB server). - LiangYuG_Altera
Contributor
Hi pp123
But maybe there is a tiny delay between "reset" & "halt" in actual system.
And that delay is more noticeable in faster system.After some experiment, there is no "tiny delay / RUNNING state" between reset & halt.
The hypothesis above is debunked.Here are some picture showing the difference between reset run & reset halt.
reset run (Processor enters ELF's _reset/reset vector immediately after reset, aka RUNNING state after reset)
reset halt (Processor enters park loop in dm_agent immediately after reset, aka HALTED state after reset)
FYI Info on park-loop/dm-agent
Unfortunately, I are unable to replicate this "double reset" issue, and require more info from your design.- Can you share a picture of your system?
(Perhaps dbg_reset_out is connected differently between your & my design) - Can you setup similar SignalTap above?
(Capture the 1st instruction with dbg_reset_out falling edge as trigger during reset halt)
Liang Yu - Can you share a picture of your system?
- pp123
And that delay is more noticeable in faster system.Yes, that may be true.
Your approach is more robust by turning it from a 4-step routine to 3-step.
Let me bring this into the team for review.So, I wait for your team's opinion.
Thank you for your research and response.
- LiangYuG_Altera
Contributor
Hi pp123
In Q24.1 Std "niosv-download -r -g exeFile.elf" works as I expect so I suppose that my NIOS V reset connections are correct.
This one is using the Ashling GDBServer. Ashling is aware of this issue & working on the fix.
I have checked that in Q24.1 Std "niosv-download -r -g -o exeFile.elf" works the same as Q25.1 (incorrect).
This one is using the OpenOCD. Agree with this observation as there is no changes to the OpenOCD flow between 24.1std & 25.1std. So, both should display this strange behaviour.
Maybe no double reset but reset earlier than app load (CPU reset -> old app execution from the beginning/load elf file -> new app execution from the beginning)?
The niosv-download runs as such (when using OpenOCD):
- reset halt
- riscv32-unknown-elf-gdb ....
- resume
So, your hypothesis is partially correct on the "reset earlier than load".
But there is a "halt" between "reset" & "load".https://openocd.org/doc/html/General-Commands.html
Theoretically, both should end the same.
- Altera's flow : Reset processor to reset vector, immediately halt on reset vector, load the new elf, resume from halted location.
- Your flow: Halt the processor, load the new elf, reset to reset vector.
And that delay is more noticeable in faster system.Your approach is more robust by turning it from a 4-step routine to 3-step.
Let me bring this into the team for review.Regards,
Liang Yu - pp123
Yes, my sequence is similar. But I'm using custom UART with FTDI device (no juart-terminal), I have Putty terminal open all the time.
In 5th step I observe some output (first logs) from APP-1.
My temporary workaround is (without niosv-shell):1. Creating cfg file:
/altera/25.1std/quartus/linux64/openocd-cfg-gen niosv.cfg2. Running OpenOCD server:
/altera/25.1std/quartus/linux64/openocd -c "tcl_port disabled" -c "gdb_port 3333" -c "telnet_port 4444" -f niosv.cfgIn the second terminal:
3. Halting CPU (optional step):
( echo "halt"; sleep 1; echo "exit"; echo EOF ) | telnet localhost 44444. Loading elf file:
/altera/25.1std/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-gdb -batch -ex "set arch riscv:rv32" -ex "set remotetimeout 60" -ex "target extended-remote localhost:3333" -ex "load exeFile.elf" -ex 'set $mstatus &= ~(0x00000088)' exeFile.elf5. Resetting CPU:
( echo "reset"; sleep 1; echo "exit"; echo EOF ) | telnet localhost 4444For example my first logs were (printf redirect to my custom UART module -> FTDI -> PC):
Hello world - Uart started!
Hello!I changed them to (only one change in app):
HELLO WORLD - UART STARTED!
Hello!
After niosv-download -r -g -o exeFile.elf execution in Putty terminal I can observe:
Hello!
Hello!
I have checked that in Q24.1 Std "niosv-download -r -g -o exeFile.elf" works the same as Q25.1 (incorrect). - LiangYuG_Altera
Contributor
Hi pp123
pp123 wrote:
Using OpenOCD causes another problem (I haven't examined it yet). During load new elf file (niosv-download -r -g -o exeFile.elf) the NIOS V CPU is starting execution of old program and then it is executing the new one (double reset?).
I am unable to replicate the "double reset" issue described.
Is your sequences similar to mine?
(Running the experiment in a single Linux terminal)- niosv-download -g -r -o APP-1.elf
- juart-terminal //Prints APP-1 output
- Ctrl-C
- niosv-download -g -r -o APP-2.elf
- juart-terminal //Prints APP-2 output only (Didn't observe any APP-1 output)
- Ctrl-C
Liang Yu
