NIOS V/m dbg_reset_out signal (Q25.1 Std, MAX10)
- 5 months ago
Hi pp123
pp123 wrote:
Signal dbg_reset_out (used for resetting HDL components) is inactive (low) when I'm using "niosv-download -r -g exeFile.elf" command (Q25.1 Std, v25.2.1 Ashling GDB Server, Linux OS, MAX10 device, NIOS V variant m).
The same command for Q24.1 Std (previous version of Ashling GDB Server, the same OS and PC) works.
For me temporary solution is using additional option -o (OpenOCD instead of Ashling® RiscFree GDB Server).LiangYuG_Altera wrote:
Please continue using OpenOCD.
We have reported this failure to Ashling for investigation.Ashling have responded to us, and fix their latest Ashling GDBServer in the upcoming RiscFree IDE v26.1.1-C in Quartus Prime Pro 26.1.1. Since you are using Quartus Prime Standard, you will need to wait for the Quartus Prime Standard 26.1 for the working Ashling GDBServer.
Liang Yu
Hi pp123
pp123 wrote:Signal dbg_reset_out (used for resetting HDL components) is inactive (low) when I'm using "niosv-download -r -g exeFile.elf" command (Q25.1 Std, v25.2.1 Ashling GDB Server, Linux OS, MAX10 device, NIOS V variant m).
LiangYuG_Altera wrote:Please continue using OpenOCD.
Liang Yu
- pp1235 months ago
Thanks for the information.
- BoonBengT_Altera5 months ago
Moderator
Dear pp123 ,
I'm glad that your issue is resolved. We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
