Need help on building kernel for ukit.
I have problems on building Linux kernel which come with ukit. It fails in the build process with following message. Can some body help me out? Thanks .
Hawkins ------------------------------------------------ Microtronix Linux Extensions Version 1.2, Built Wed Jul 27 3:46pm EST 2004 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' nios2-elf-gcc: not found nios2-elf-gcc: not found Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel nios2-elf-gcc: not found SYMLINK include/asm -> include/asm-nios2nommu nios2-elf-gcc: not found nios2-elf-gcc: not found HOSTCC scripts/basic/fixdep scripts/basic/.fixdep.d: done. HOSTCC scripts/basic/split-include scripts/basic/.split-include.d: done. HOSTCC scripts/basic/docproc scripts/basic/.docproc.d: done. nios2-elf-gcc: not found HOSTCC scripts/conmakehash scripts/.conmakehash.d: done. HOSTCC scripts/kallsyms scripts/.kallsyms.d: done. HOSTCC scripts/mk_elfconfig scripts/.mk_elfconfig.d: done. MKELF scripts/elfconfig.h HOSTCC scripts/file2alias.o scripts/.file2alias.o.d: done. HOSTCC scripts/modpost.o scripts/.modpost.o.d: done. HOSTCC scripts/sumversion.o scripts/.sumversion.o.d: done. HOSTLD scripts/modpost HOSTCC scripts/pnmtologo scripts/.pnmtologo.d: done. HOSTCC scripts/bin2c scripts/.bin2c.d: done. nios2-elf-gcc: not found nios2-elf-gcc: not found make[2]: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 127 make[1]: *** [arch/nios2nommu/kernel/asm-offsets.s] Error 2 make: *** [all] Error 2 CC arch/nios2nommu/kernel/asm-offsets.s make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'9 Replies
There's an issue with v1.1 of the Nios II Linux Distribution where the nios2-elf tools can't be found if SOPC Builder hasn't been run at least once on the workstation.
The symptoms that you're describing match the problem exactly. Try running SOPC Builder from the Nios II SDK Shell commandline.
When prompted to create a new system, just click cancel and then close down SOPC Builder. After performing those steps, try re-building your kernel through the IDE.$ SOPC_BUILDER - Altera_Forum
TO_BE_DONE
Hi, the default configuration provided with the kernel automatically includes the IDE drivers. Since the uKit hardware designs don't include IDE support, the drivers for IDE won't build properly.
To correct the problem, configure your kernel (procedure can be found in the getting started guide) and turn off Device Drivers -> ATA/ATAPI/MFM/RLL support for your kernel. After saving the configuration, try rebuilding the kernel again. - Altera_Forum
Hi Kent,
I can complete the build for the kernel, but fail on the kernel upload. Thanks again. Please see the following: ------------------------------------------------ Microtronix Linux Extensions Version 1.2, Built Wed Jul 27 3:46pm EST 2004 ------------------------------------------------ Oct 6, 2004 8:22:08 AM - (INFO) nios2-flash-programmer: Launching Quartus Programmer to download: $COMPONENTSDIR/mtx_nios_dev_board_cyclone_1c12/system/mtx_nios_dev_board_cyclone_1c12.sof Error: Can't locate programming file in Chain Description File Oct 6, 2004 8:22:12 AM - (SEVERE) nios2-flash-programmer: Unable to download SOF: $COMPONENTSDIR/mtx_nios_dev_board_cyclone_1c12/system/mtx_nios_dev_board_cyclone_1c12.sof, exiting Hawkins - Altera_Forum
I'll have to get back to you about this one. I'm not entirely sure why that's happening.
Hi Ken,
Have you found anything Yet? Hawkins - Altera_Forum
I've been looking into it for the past day or so and nothing came up in any of my searches for the keyword COMPONENTSDIR. I just found out where that COMPONENTSDIR keyword appears... it's in the following file:
.../Documents and Settings/<your username>/.sopc_builer/install.ptf The $COMPONENTSDIR keyword should be replaced with <location of Nios II Dev Kit>/components As an example, if you installed the Altera Nios II Development Kit in c:/altera/kits/nios2 then all instances of $COMPONENTSDIR would be replaced with c:/altera/kits/nios2/components Let me know if it helps... and I'll talk to our installshield guy in the meantime to let him know there might be a bug in the installer for the uKit. - Altera_Forum
Hi Ken,
After changed the path in install.ptf as you adviced, I can upload the kernel now. Thanks again. Hawkins - Altera_Forum
Not a problem. Hope your project goes well. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
