21 years agoNeed help on building kernel for ukit.
I have problems on building Linux kernel which come with ukit. It fails in the build process with following message. Can some body help me out? Thanks . Hawkins -----------------------...
21 years agoI've been looking into it for the past day or so and nothing came up in any of my searches for the keyword COMPONENTSDIR. I just found out where that COMPONENTSDIR keyword appears... it's in the following file:
.../Documents and Settings/<your username>/.sopc_builer/install.ptf The $COMPONENTSDIR keyword should be replaced with <location of Nios II Dev Kit>/components As an example, if you installed the Altera Nios II Development Kit in c:/altera/kits/nios2 then all instances of $COMPONENTSDIR would be replaced with c:/altera/kits/nios2/components Let me know if it helps... and I'll talk to our installshield guy in the meantime to let him know there might be a bug in the installer for the uKit.
