21 years agoNeed help on building kernel for ukit.
I have problems on building Linux kernel which come with ukit. It fails in the build process with following message. Can some body help me out? Thanks . Hawkins -----------------------...
21 years agoThere's an issue with v1.1 of the Nios II Linux Distribution where the nios2-elf tools can't be found if SOPC Builder hasn't been run at least once on the workstation.
The symptoms that you're describing match the problem exactly. Try running SOPC Builder from the Nios II SDK Shell commandline.$ SOPC_BUILDER When prompted to create a new system, just click cancel and then close down SOPC Builder. After performing those steps, try re-building your kernel through the IDE.
