10 years agomSGDMA, Qsys, and Linux Integration
So I've been trying to get the Modular SG-DMA working in a Qsys project tied with Linux. I can get it to show up in the device tree, be recognized by Linux in /sys, and it looks like the memory mapping works.
Below is a clip from the msgdma in my device tree: msgdma_0: msgdma@0x100000020 { compatible = "altr,msgdma-14.1", "altr,msgdma-1.0"; reg = <0x00000001 0x00000020 0x00000020>, <0x00000001 0x00000010 0x00000010>; reg-names = "csr", "descriptor_slave"; interrupt-parent = <&hps_0_arm_gic_0>; interrupts = <0 41 4>; clocks = <&clk_0>; }; //end msgdma@0x100000020 (msgdma_0) Now the interesting part of all this is that there are no drivers for altr,msgdma-1.0 available in the 3.10-ltsi. While direct memory mapping will probably work to write to the descriptor, has anyone had any luck with writing mSGDMA descriptors from the HPS? It looks like people have been able to use the Altera DMA Controller, no problem, but the mSGDMA provides a wider bus width and more configurable options that could be highly beneficial for an FPGA-to-HPS bridge. Thanks!27 Replies
--- Quote Start --- For any one else having issues, I was running in to an issue where the Qsys interconnect (or something on the Descriptor-write side) was causing problems with triggering the DMA, leading the DMA to act very odd. Even so, I need to add a <100 ms delay after initiating and completing the first mSGDMA run before I can start using the DMA correctly. I'm wondering if there is some sort of initialization procedure that isn't covered by a reset that is not being accounted for? --- Quote End --- Has anyone been able to use the mSGDMA in park mode for an ST-to-MM transfer, and then reset the mSGDMA? I'm finding that I can't reset the DMA once I have started park mode, with the CSR getting stuck at a value of 0x5 (reset, run). In addition, it looks like the mSGDMA only writes the Owned-by-HW bit during descriptor write back, meaning that having a linked list set up to point back at itself will fill the descriptor FIFO on the initial fetch. I might be wrong about this as well, but the documentation is very unclear. BadOmen? - Altera_Forum
derim -
I want to thank you for continuing to post your mSGDMA progress here even though you're getting very little if any help or feedback. I'm in the process of folding the mSGDMAs into our A10 SoC dev kit design to DMA between HPS memory and FPGA memory. I'll share any problems and/or solutions we find. Bob - Altera_Forum
--- Quote Start --- derim - I want to thank you for continuing to post your mSGDMA progress here even though you're getting very little if any help or feedback. I'm in the process of folding the mSGDMAs into our A10 SoC dev kit design to DMA between HPS memory and FPGA memory. I'll share any problems and/or solutions we find. Bob --- Quote End --- As we're running on custom hardware, I've also contacted my FAE and Altera directly through support. It's very frustrating as nothing seems to be performing in a deterministic/expected manner. On a related note, it is fascinating, but I can't figure out how to get an mSGDMA out of park mode. I'm obviously doing something in the wrong order, but nothing in the documentation is providing strict guidance. It also is odd that the first capture that I do fails, but the second always works. I'm thinking there is something distinctly wrong here. It might make sense to switch to the Altera scatter-gather from the mSGDMA if this continues. Considering the mSGDMA is used in all the Altera components (TSE), something else is probably going on. - Altera_Forum
We borrowed a Cyclone V dev kit from our local Altera account manager and ran this reference design on that board successfully:
https://releases.rocketboards.org/release/2014.05/tse-ed/hw As you mentioned, this design uses mSGDMAs between HPS memory and the TSE. Since the Linux drivers were happy with the configuration of those mSGDMAs that became my template for our Arria 10 SoC design. Maybe you can figure something out by inspection. We should be testing our design next week and I'll let you know what we see. Bob - Altera_Forum
Bob,
I don't think I mentioned, but my mSGDMA hooked up to SDRAM works near flawlessly, except for an issue where the first 2046 bytes out are zeroes. After that it works great, I believe, but am not sure if I'm seeing discontinuous points at the boundary on starting a run. This is the data path fifo depth, so it's highly suspicious behavior. I'm also not using packetized data. The ones that have trouble are tied to onchil memory tied to the fast bus. https://github.com/altera-opensource/linux-socfpga/blob/a24e3d414e59ac76566dedcad1ed1d319a93ec14/drivers/net/ethernet/altera/altera_msgdma.c Thanks for the thought-- but no exact luck on this. The only difference might be their clearing of the status register before resetting the mSGDMA, but they are also not using a prefetcher. The DMAs that I'm working with require the ability to go in to park mode for continuous data transfer/interrupts, or at least a good facsimile thereof. I'll definitely try to clear the status bits first and after, though. And switch to unaligned accesses per the rocketboards recommendations. Cheers, Josh - Altera_Forum
--- Quote Start --- I do control mSGDMA with lightweight AXI In QSys: CSR, Descriptor, Response connected to lw_axi_master mm_write connected to f2h_axi_slave In Linux: open /dev/mem mmap to 0xFF200000 with offset of registers addresses
--- Quote End --- What value is MAP_PIO_SIZE?# pragma pack(push,1) /** * @brief mSGDMA control and status register */ typedef struct { uint32_t status; uint32_t control; uint16_t rd_fill_level; uint16_t wr_fill_level; uint16_t resp_fill_level; uint16_t reserved_0; uint16_t rd_sequence_number; uint16_t wr_sequence_number; uint32_t reserved_1; uint32_t reserved_2; uint32_t reserved_3; } t_mSGDMA_CSR; # pragma pack(pop) t_mSGDMA_CSR * regs_CSR; fd_FPGA_ctrl_regs = open("/dev/mem", O_RDWR|O_SYNC); mem_FPGA_ctrl_regs = (unsigned int*)mmap(NULL, MAP_PIO_SIZE, PROT_READ|PROT_WRITE, MAP_SHARED, fd_FPGA_ctrl_regs, 0xFF200000); regs_CSR= (t_mSGDMA_CSR*)(p_mmap_mSGDMA_control + mSGDMA_CSR_offset / sizeof(uint32_t)); /* descriptor, response is the same */ /* and registers are ready to use */ - Altera_Forum
--- Quote Start --- What value is MAP_PIO_SIZE? --- Quote End --- Here's where things stand now: - I can use them fine, but I am unable to cancel/reset an mSGDMA when using park mode. I think, to get around this, those mSGDMA modules will be started on startup and not touched after. - Altera informed me that there was a synthesis bug that sometimes showed up related to descriptor writes in Quartus before 15.1.1, so I might have been seeing issues with that. Using the pre-fetcher works well for me, so I might try a no-prefetcher design again later. - The mSGDMA module has a FIFO that it uses for the data path. This FIFO has a READY line out that ONLY signals that the FIFO is not full. This means that if doing an Avalon-ST to Avalon-MM DMA transaction the design must be very careful to NOT fill the FIFO while the DMA is not running, or you will see corrupted data. The fix for this is to have a module that only sends the number of valids that should go in to each DMA transaction each time. Example: Start a single-shot of the DMA for n transactions, then start the FPGA-based streamer to send n transactions. Example 2: Turn on DMA for park mode, then turn on transaction streamer. Stopping park should involve deasserting the bit, waiting for the Run to end, and then turning off the streamer before resetting the DMA. I have not been able to get this to work yet and instead the DMA gets stuck in reset. It would be really nice if the DMA module "ready" was actually a "DMA ready to receive," but it is not. - Altera_Forum
--- Quote Start --- What value is MAP_PIO_SIZE? --- Quote End --- Also, in reply to this one-- I updated all my memory mappings and sizes recently. I wouldn't call it MAP_PIO_SIZE, but instead LW_REGS_SIZE, which is 2 MB. Check out page 1-19 and 7-6 of the HPS Technical Reference Manual. The LW FPGA devices run from 0xFF200000 to 0xFF400000, or 0x200000. This gets mapped to virtual memory in Linux, and there is also the fast bridge which runs from 0xC0000000 and is 960 MB, or to 0xFC000000 (0x3C000000 size). The graphic on 7-6 saved me a lot of time. - Altera_Forum
--- Quote Start --- Also, in reply to this one-- I updated all my memory mappings and sizes recently. I wouldn't call it MAP_PIO_SIZE, but instead LW_REGS_SIZE, which is 2 MB. Check out page 1-19 and 7-6 of the HPS Technical Reference Manual. The LW FPGA devices run from 0xFF200000 to 0xFF400000, or 0x200000. This gets mapped to virtual memory in Linux, and there is also the fast bridge which runs from 0xC0000000 and is 960 MB, or to 0xFC000000 (0x3C000000 size). The graphic on 7-6 saved me a lot of time. --- Quote End --- Everything works, except I can't turn off park mode on the mSGDMA module without freezing Linux. I think that the DMAs really would benefit from a generic UIO kernel driver being available to handle things such as resets, etc. Waiting to hear back from Altera about the best method to reset a module in park mode. - Altera_Forum
--- Quote Start --- What value is MAP_PIO_SIZE? --- Quote End --- # define MAP_PIO_SIZE (0x00100000) In my case I dedicate 1 MB of top of memory to FPGA. To dedicate it to FPGA I start kernel with mem option setenv net_nfs run netload nfsargs addip addargs \; bridge enable \; bootm ${kernel_addr_r} - ${fdt_addr} mem=0x3FF00000 where 0x3FF00000 is 2 GB ( RAM installed on the board ) - 1 MB (dedicated to FPGA)
