19 years ago
Motion-JPEG decoder/encoder
Hi,everybody:
I used Altera DE2 board and Web Camera.
I will display image in IE through boa web server ( Motion-JPEG format) .
but I don't know how to decoder/encoder images.
Anyone can give me some hint?
please
regards
Faye
    --- Quote Start ---
    originally posted by faye@Jan 12 2007, 09:47 AM
    hi,hippo
    ps: i used terasic's camera module through 40pins headers.
    regards
    faye
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20517)
    --- quote end ---
    --- Quote End ---
    I will try to get one.
    I am stilling looking at the video capture driver, at linux-2.6.x/drivers/media/video.
    I didn&#39;t figure out how to write the driver yet.
    I am busy with the latest uClinux-dist-20070130 release at the moment.
    I had I2C driver working. I will move to video capture later.
    --- Quote Start ---
    originally posted by hippo@Feb 6 2007, 09:21 PM
    i am busy with the latest uclinux-dist-20070130 release at the moment.
    i had i2c driver working. i will move to video capture later.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=21309)
    --- quote end ---
    --- Quote End ---
    ok! thank you again!
    I&#39;m waiting for you!
    You are a very nice man!
    Faye
    hi, hippo
    I used DE2&#39;s camera module through 40 pins headers.
    The webcam&#39;s data is RGB format.
    I will transmit images form DE2 board to PC, then process images, so I need compress and decompress it.(JPEG Format)
    My problem is how to transform RGB format become JPEG format.
    Can you give me more hint or information?
    I need your help! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
    Faye
    PS: Can I use V4L to do it?
    There&#39;s no way you&#39;ll be able to do this in software....not with a decent framerate, at least. There&#39;s a JPEG hardware compressor at Opencores.org. You might take a crack at converting it for use in SOPC Builder or....you could try using C2H for the DCT, at a minimum.
    In any case, you&#39;ve a lot of reading to do. There&#39;s ample information on JPEG compression/de-compression on the web.
    Good luck!
    - slacker
    Hi !
    I am new hand to NiosII and uClinux.
    I have the same problem with you.But the difference is I will use the Vidio In as the input.
    Have you work it out?
    My puzzle is how can I get the Vidios at uClinux.
    I want to share this topic with you
    thank you very much.
