19 years agoMotion-JPEG decoder/encoder
Hi,everybody: I used Altera DE2 board and Web Camera. I will display image in IE through boa web server ( Motion-JPEG format) . but I don't know how to decoder/encoder images. Anyone can...
19 years agoThere's no way you'll be able to do this in software....not with a decent framerate, at least. There's a JPEG hardware compressor at Opencores.org. You might take a crack at converting it for use in SOPC Builder or....you could try using C2H for the DCT, at a minimum.
In any case, you've a lot of reading to do. There's ample information on JPEG compression/de-compression on the web. Good luck! - slacker
