15 years agoMODPOST __copy_from_user module compilation issue
Hello!
I'm encountering a problem while compiling USB modules under Nios2Linux-MMU. In Kernel config I select USB Host driver support and execute 'make modules'. At the end of the process I get the following errors:
Building modules, stage 2.
MODPOST 21 modules
ERROR: "__copy_from_user" undefined!
ERROR: "__copy_to_user" undefined!
Does anyone know good documentation about this modpost stuff? Actually I have no clue and can't find anything on this topic... Btw, also when I use the __copy_*_user and copy_*_user in my own modules it results in the same error. As a workaround 've been using the put_user and get_user functions. But this couldn't be a solution. regards steron10 Replies
It seems nobody can help me. I'm still trying to fix that and found out some things:
Now I'm trying to compile my own module where I use the function mentioned above. The module is a char device driver and the important parts are the following:
Now i don't get the errors anymore, but warnings instead:# include <linux/init.h># include <linux/module.h># include <linux/ioport.h># include <linux/fs.h># include <asm/io.h># include <asm/uaccess.h> __copy_from_user(cmd,buffer,2);
The Makefile: (for building outside the kernel tree)Building modules, stage 2. MODPOST 1 modules WARNING: "__copy_from_user" undefined!
Eventually the module is built, but when I try to plug it into the running kernel, I get this error:obj-m := mymod.o all: $(MAKE) -C ../../../uClinux-dist SUBDIRS=$(PWD) modules
Am I missing something here? Cause the symbol _is_ actually defined, as I can see from /proc/kallsyms:root:~> insmod mymod.ko mymod: Unknown symbol __copy_from_user insmod: can't insert 'mymod.ko': unknown symbol in module, or unknown parameter
One other thing I've found is this post on the forum: http://www.alteraforum.com/forum/showthread.php?t=14426 (http://www.alteraforum.com/forum/showthread.php?t=14426&highlight=copy_from_user) wentao suggests to include another EXPORT_SYMBOL in the according file. I did the same in arch/nios/mm/uaccess.c but it didn't help. Thanks for your support steronroot:~> cat /proc/kallsyms | grep copy_from_user c8006854 T __copy_from_user c8008210 T copy_from_user_page c805075c t __iovec_copy_from_user_inatomic c805081c T iov_iter_copy_from_user c80508ac T iov_iter_copy_from_user_atomic c8086654 t pipe_iov_copy_from_user c8123d58 T csum_partial_copy_from_user - Altera_Forum
--- Quote Start --- It seems nobody can help me. I'm still trying to fix that and found out some things: --- Quote End --- Before complaining to forum members, please 'grep' the kernel source directories and find the definition of '__copy_from_user'. Maybe it exists in the file /nios2-linux/linux-2.6/arch/nios2/mm/uaccess.c and its header file is /nios2-linux/linux-2.6/arch/nios2/include/uaccess.h And please check again whether your 'include path' is right or not. Kazu - Altera_Forum
Hi!
--- Quote Start --- Before complaining to forum members --- Quote End --- Complaining was not my intention. I'm sorry if it sounded like that. I just wanted to give you more information because the error messages from my first were probably not enough. I checked the definition of the function and the include path. Eventually I put the EXPORT_SYMBOL(__copy_from_user); line into the arch/nios2/mm/uaccess.c file. Don't know if it's only a workaround, because it seems strange that other users haven't encountered such errors. By the way, in my last post when I wrote --- Quote Start --- I did the same in arch/nios/mm/uaccess.c but it didn't help. --- Quote End --- I just got confused with the directories in my kernel tree. Surprisingly I got another 'nios2' directory below 'arch/nios2' but this seems to be a result of any messy copying action. - Altera_Forum
--- Quote Start --- I checked the definition of the function and the include path. Eventually I put the EXPORT_SYMBOL(__copy_from_user); line into the arch/nios2/mm/uaccess.c file. Don't know if it's only a workaround, because it seems strange that other users haven't encountered such errors. --- Quote End --- You mean that you don't have the description EXPORT_SYMBOL(__copy_from_user); in your 'uaccess.c' file ? Modules are loaded dynamically and the linker must resolve the locations. To do this, the kernel must expose the symbol's location, and you need the macro 'EXPORT_SYMBOL(symbol)' if you want to use the 'symbol' in your module. In fact, the symbols
are exported in my 'arch/nios2/mm/uaccess.c'. The macro 'EXPORT_SYMBOL' exports symbols as followsEXPORT_SYMBOL(__copy_from_user); EXPORT_SYMBOL(copy_from_user); EXPORT_SYMBOL(__copy_to_user); EXPORT_SYMBOL(copy_to_user); EXPORT_SYMBOL(get_ds); EXPORT_SYMBOL(get_fs); EXPORT_SYMBOL(set_fs);
And it seems that Wind River guys did not test the module loadings at all. Please see this http://www.alteraforum.com/forum/showpost.php?p=78791&postcount=48 . Kazu/* For every exported symbol, place a struct in the __ksymtab section */# define __EXPORT_SYMBOL(sym, sec) extern typeof(sym) sym; __CRC_SYMBOL(sym, sec) static const char __kstrtab_##sym __attribute__((section("__ksymtab_strings"), aligned(1))) = MODULE_SYMBOL_PREFIX# sym; static const struct kernel_symbol __ksymtab_##sym __used __attribute__((section("__ksymtab" sec), unused)) = { (unsigned long)&sym, __kstrtab_##sym } # define EXPORT_SYMBOL(sym) __EXPORT_SYMBOL(sym, "") - Altera_Forum
Shame on me, I actually got confused with file versioning. In the recent versions there are the correct macro calls in 'arch/nios2/mm/uaccess.c' and others.
Thanks for the hint! steron - Altera_Forum
Steron,
I actually have the same problem. Can you tell me how you fixed it? Thanks - Altera_Forum
I got all the necessary definitions simply by updating to the most recent git tree. :-)
Where exactly are you encountering this problem? - Altera_Forum
I inserted my module and I got a unknown symbol error.
Hey,
I think we need more information on your module. Can you show us some code? - Altera_Forum
I did a upgrade and the problem has gone. thanks
