15 years agoMODPOST __copy_from_user module compilation issue
Hello! I'm encountering a problem while compiling USB modules under Nios2Linux-MMU. In Kernel config I select USB Host driver support and execute 'make modules'. At the end of the process ...
15 years agoShame on me, I actually got confused with file versioning. In the recent versions there are the correct macro calls in 'arch/nios2/mm/uaccess.c' and others.
Thanks for the hint! steron
