15 years agoMODPOST __copy_from_user module compilation issue
Hello! I'm encountering a problem while compiling USB modules under Nios2Linux-MMU. In Kernel config I select USB Host driver support and execute 'make modules'. At the end of the process ...
15 years agoIt seems nobody can help me. I'm still trying to fix that and found out some things:
Now I'm trying to compile my own module where I use the function mentioned above. The module is a char device driver and the important parts are the following:# include <linux/init.h># include <linux/module.h># include <linux/ioport.h># include <linux/fs.h># include <asm/io.h># include <asm/uaccess.h>
__copy_from_user(cmd,buffer,2);
Now i don't get the errors anymore, but warnings instead:
Building modules, stage 2.
MODPOST 1 modules
WARNING: "__copy_from_user" undefined!
The Makefile: (for building outside the kernel tree)
obj-m := mymod.o
all:
$(MAKE) -C ../../../uClinux-dist SUBDIRS=$(PWD) modules
Eventually the module is built, but when I try to plug it into the running kernel, I get this error:
root:~> insmod mymod.ko
mymod: Unknown symbol __copy_from_user
insmod: can't insert 'mymod.ko': unknown symbol in module, or unknown parameter
Am I missing something here? Cause the symbol _is_ actually defined, as I can see from /proc/kallsyms:
root:~> cat /proc/kallsyms | grep copy_from_user
c8006854 T __copy_from_user
c8008210 T copy_from_user_page
c805075c t __iovec_copy_from_user_inatomic
c805081c T iov_iter_copy_from_user
c80508ac T iov_iter_copy_from_user_atomic
c8086654 t pipe_iov_copy_from_user
c8123d58 T csum_partial_copy_from_user
One other thing I've found is this post on the forum: http://www.alteraforum.com/forum/showthread.php?t=14426 (http://www.alteraforum.com/forum/showthread.php?t=14426&highlight=copy_from_user) wentao suggests to include another EXPORT_SYMBOL in the according file. I did the same in arch/nios/mm/uaccess.c but it didn't help. Thanks for your support steron
