20 years ago
Missing writes on Custom board
I have an interesting problem. I have designed a NIOS system that I have implemented onto a custom boad. I have written a simple frimware program to check parts of the system. When I execute the firmware using the debug download of the IDE I get all the expected writes. However when I execute the firmware using the "run" download a lot of the writes are missed. I thought this may be related to some sort of configuration of the IDE. However when I downloaded my code to the EPCS and ran from there on a reset I got the same results !?
I found this bug both when writing to my Dual Port Ram (via a custom component) and also my Logic Interface (via a custom component)!
Does anyone has any suggestion ?
    --- Quote Start ---
    originally posted by shmueld@May 16 2006, 05:10 PM
    i have an interesting problem. i have designed a nios system that i have implemented onto a custom boad. i have written a simple frimware program to check parts of the system. when i execute the firmware using the debug download of the ide i get all the expected writes. however when i execute the firmware using the "run" download a lot of the writes are missed. i thought this may be related to some sort of configuration of the ide. however when i downloaded my code to the epcs and ran from there on a reset i got the same results !?
    i found this bug both when writing to my dual port ram (via a custom component) and also my logic interface (via a custom component)!
    does anyone has any suggestion ?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15408)
    --- quote end ---
    --- Quote End ---
    Try to use a NIOS without caches - if it then works you should check your hardware access commands (always use IO commands to access hardware and not C pointers).
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15424)</div>
    --- Quote End ---
    Dear stonie,
    Thanks for your reply. I am not a software guy, so could you please explain to me what you mean by : "always use IO commands to access hardware and not C pointers" and why this should make a difference when running the code on my custom hardware directly compared to debug mode (which doesn&#39;t work properly)?
    Are you using -O2 or -O3 in the run configuration? there may be some optimizations done by the compiler that removes some "unuseful" writes to memory.... did you declared your data as "volatile"?
    Paolo
    Another Interesting result:-
    When I was carrying out single writes to my cusotmized NIOS logic Interface component, after every write I found that reads of every single address in the range of the interface was being done. With further investigation I found that these reads were even being done during the initialization of the pointers - (yes we are using pointers - I have requested from the software enginner to look into changing this and use "IO commands to access hardware " - although we are not yet sure what these are !) !
    Does Anyone have any further suggestions ?
    Note I have also requested from the Software Engineer to try to bypass the cache - it is all done through the softeware right ?
    --- Quote Start ---
    --- quote end ---
    --- Quote End ---
    Read through the Nios II Software User&#39;s Guide. All of your answers/options are clearly stated there.
    - slacker
