20 years agoMissing writes on Custom board
I have an interesting problem. I have designed a NIOS system that I have implemented onto a custom boad. I have written a simple frimware program to check parts of the system. When I execute the firm...
20 years ago --- Quote Start --- originally posted by shmueld@May 16 2006, 08:10 AM i have an interesting problem. i have designed a nios system that i have implemented onto a custom boad. i have written a simple frimware program to check parts of the system. when i execute the firmware using the debug download of the ide i get all the expected writes. however when i execute the firmware using the "run" download a lot of the writes are missed. i thought this may be related to some sort of configuration of the ide. however when i downloaded my code to the epcs and ran from there on a reset i got the same results !?
i found this bug both when writing to my dual port ram (via a custom component) and also my logic interface (via a custom component)!
does anyone has any suggestion ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15408)
--- quote end ---
--- Quote End --- Read through the Nios II Software User's Guide. All of your answers/options are clearly stated there. - slacker
