20 years agoMissing writes on Custom board
I have an interesting problem. I have designed a NIOS system that I have implemented onto a custom boad. I have written a simple frimware program to check parts of the system. When I execute the firm...
20 years agoAre you using -O2 or -O3 in the run configuration? there may be some optimizations done by the compiler that removes some "unuseful" writes to memory.... did you declared your data as "volatile"?
Paolo
