Well, finally managed to store filesystem in Flash, now I've much more free memory in my DE1 board. here it is:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 6-1.1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 2.6.34-00693-ga32ca88-dirty (
mcesar@mcesarpc4114c.sec.upm.es) (gcc version 4.1.2)# 331 PREEMPT Tue Jul 13 20:28:55 CEST 2010
Linux/Nios II-MMU
init_bootmem_node(?,0x101bf, 0x10000, 0x10800)
free_bootmem(0x101bf000, 0x641000)
reserve_bootmem(0x101bf000, 0x100)
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032
Kernel command line: root=/dev/mtdblock0 rootfstype=jffs2 ro
PID hash table entries: 32 (order: -5, 128 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
We have 67584 pages of RAM
Memory available: 6316k/1785k RAM, 0k/0k ROM (1402k kernel code, 382k data)
NR_IRQS:32
Calibrating delay loop... 49.15 BogoMIPS (lpj=245760)
Mount-cache hash table entries: 512
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
Switching to clocksource timer
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
JFS: nTxBlock = 49, nTxLock = 394
io scheduler noop registered (default)
ttyJ0 at MMIO 0x1801420 (irq = 1) is a Altera JTAG UART
console [ttyJ0] enabled
physmap platform flash device: 00400000 at 01400000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 2 MTD partitions on "physmap-flash.0":
0x000000200000-0x000000400000 : "romfs/jffs2"
0x000000000000-0x000000200000 : "loader/kernel"
VFS: Mounted root (jffs2 filesystem) readonly on device 31:0.
Freeing unused kernel memory: 44k freed (0xd0160000 - 0xd016a000)
ifconfig: socket: Function not implemented
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/ BusyBox v1.16.2 (2010-07-12 20:38:43 CEST) hush - the humble shell
Enter 'help' for a list of built-in commands.
root:/> free
total used free shared buffers
Mem: 6360 3124 3236 0 0
Swap: 0 0 0
Total: 6360 3124 3236
root:/> mount
rootfs on / type rootfs (rw)
/dev/root on / type jffs2 (ro,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600)
var on /var type ramfs (rw,relatime)
tmp on /tmp type tmpfs (rw,nosuid,nodev,relatime)
root:/>
