16 years agoMinimal MMU linux hangs on DE1 board
Hi all, when trying to build my first MMU linux on a DE1 board system hangs just after nios2-terminal with: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-term...
16 years agoWell, after adjusting SDRAM's timing & PLL I found that the problem is not enough memory. Eight MB seems to little for even a bare minimum MMU linux to work. I switched back to uClinux.
