16 years agoMinimal MMU linux hangs on DE1 board
Hi all, when trying to build my first MMU linux on a DE1 board system hangs just after nios2-terminal with: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-term...
16 years agoS O L V E D
I've changed cache sizes downto 4 kB and now takes longer to hang B U T still hangs after: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 6-1.1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.34-00692-g5bc7853-dirty ([email protected] version 2.6.34-00692-g5bc7853-dirty (root at mcesarpc4114c.sec.upm.es) (gcc version 4.1.2)# 100 Thu Jun 24 19:01:16 CEST 2010 bootconsole [early0] enabled early_console initialized at 0xe8400020 Linux/Nios II-MMU init_bootmem_node(?,0x10421, 0x10000, 0x10800) free_bootmem(0x10421000, 0x3df000) reserve_bootmem(0x10421000, 0x100) Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032 Kernel command line: PID hash table entries: 32 (order: -5, 128 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) We have 67584 pages of RAM Memory available: 3876k/4224k RAM, 0k/0k ROM (1175k kernel code, 3048k data) Hierarchical RCU implementation. NR_IRQS:32 Calibrating delay loop... 5.72 BogoMIPS (lpj=28608) Mount-cache hash table entries: 512 init_BSP(): registering device resources bio: create slab <bio-0> at 0 Switching to clocksource timer Says 0k/0k ROM as I have removed the CFI flash for now. As before, any help will be wellcome.
