22 years ago
Linux Kernel Configuration failes
I installed the V1.1 and still not be able to launch the configuration window after creating a new project based on Linux kernel. The BASH window appear and disappear. I have been able to get a screen shot to see the error message. Unfortunately I cannot attached it. Where can I post the screen shot ?
I am using Window XP. I saw topics related to window Patches. Is it also due for XP ?
    Maga, I suspect that I am experiencing the same problem. I too had a window appear & disappear almost immediately!
    I ran the same code from the command prompt so that I could capture the output error. Here is what it reads:
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    Microtronix Linux Extensions
    Version 1.1, Built Wed Jul 7 12:46pm EST 2004
    make: Entering directory `/cygdrive/c/Altera/kits/nios2/bin/eclipse/plugins/com.
    microtronix.nios2linux.kernel_0.1.5/linux-2.6.x&#39;
    HOSTCC scripts/basic/fixdep
    /usr/local/bin/ld: cannot open crt0.o: No such file or directory
    collect2: ld returned 1 exit status
    make[2]: *** [scripts/basic/fixdep] Error 1
    make[1]: *** [scripts_basic] Error 2
    make: *** [menuconfig] Error 2
    make: Leaving directory `/cygdrive/c/Altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x&#39;[/b]
    --- Quote End ---
    Can you confirm if this error is the same as yours?
    Anyone know why I am getting this error?
    Here is the command that gets launched:
    --- Quote Start ---
    C:\Altera\quartus41\bin>C:/Altera/quartus41/bin/cygwin/bin/bash.exe -c "source $QUARTUS_ROOTDIR/sopc_builder/bin/nios_sh; source $SOPC_KIT_NIOS2/user.bashrc; KERNEL_PROJECT=c:/altera/kits/nios2/bin/eclipse/workspace/kernel_1c20; make -C `cygpath -u C:/Altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x` O=`cygpath -u c:/altera/kits/nios2/bin/eclipse/workspace/kernel_1c20/build` menuconfig; "[/b]
    --- Quote End ---
    I applied the "Window NT" patch to my Window XP system, although I&#39;m not sure if the patch could work with XPs.
    The configuration worked fine, and the entire installation process succeeded.
    Version: Windows XP Professional (Build 2600) SP 1
    sekiyama
    Hitachi High-Technologies Corp., Japan
    sekiyama, thanks for the tip!!! I&#39;ve got it working!
    FYI, I applied the NT patch to my Win2K system and voila, it works.
    Thanks again,
    tjd
    How can I apply the patch in Windows NT 2k???
    thanks
    Adriano
    aksanche,
    The instructions to apply the patch are found where you downloaded the patch. I have included them here:
    --- Quote Start ---
    Extract file &#39;userdirs.tar.Z&#39; and save in /usr [generally: c:\quartus\bin\cygwin\usr]
    Unmount /usr/lib [command from NiosII SDK Shell: &#39;umount /usr/lib&#39;]
    Un-tar &#39;userdirs.tar.Z&#39; [command from NiosII SDK Shell, issued from /usr: &#39;tar -xzf userdirs.tar.Z]
    Extract &#39;microtronix.bashrc&#39; and rename as &#39;user.bashrc&#39; in c:\altera\kits\nios2 [or append to existing &#39;user.bashrc&#39; with command &#39;cat microtronix.bashrc >> user.bashrc&#39;][/b]
    --- Quote End ---
