22 years agoLinux Kernel Configuration failes
I installed the V1.1 and still not be able to launch the configuration window after creating a new project based on Linux kernel. The BASH window appear and disappear. I have been able to get a scree...
22 years agoMaga, I suspect that I am experiencing the same problem. I too had a window appear & disappear almost immediately!
I ran the same code from the command prompt so that I could capture the output error. Here is what it reads: <div class='quotetop'>QUOTE </div> --- Quote Start --- ------------------------------------------------ Microtronix Linux Extensions Version 1.1, Built Wed Jul 7 12:46pm EST 2004 ------------------------------------------------ make: Entering directory `/cygdrive/c/Altera/kits/nios2/bin/eclipse/plugins/com. microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' HOSTCC scripts/basic/fixdep /usr/local/bin/ld: cannot open crt0.o: No such file or directory collect2: ld returned 1 exit status make[2]: *** [scripts/basic/fixdep] Error 1 make[1]: *** [scripts_basic] Error 2 make: *** [menuconfig] Error 2 make: Leaving directory `/cygdrive/c/Altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/b] --- Quote End --- Can you confirm if this error is the same as yours? Anyone know why I am getting this error? Here is the command that gets launched: <div class='quotetop'>QUOTE </div> --- Quote Start --- C:\Altera\quartus41\bin>C:/Altera/quartus41/bin/cygwin/bin/bash.exe -c "source $QUARTUS_ROOTDIR/sopc_builder/bin/nios_sh; source $SOPC_KIT_NIOS2/user.bashrc; KERNEL_PROJECT=c:/altera/kits/nios2/bin/eclipse/workspace/kernel_1c20; make -C `cygpath -u C:/Altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x` O=`cygpath -u c:/altera/kits/nios2/bin/eclipse/workspace/kernel_1c20/build` menuconfig; "[/b] --- Quote End ---
