22 years agoLinux Kernel Configuration failes
I installed the V1.1 and still not be able to launch the configuration window after creating a new project based on Linux kernel. The BASH window appear and disappear. I have been able to get a scree...
22 years agoaksanche,
The instructions to apply the patch are found where you downloaded the patch. I have included them here: <div class='quotetop'>QUOTE </div> --- Quote Start --- Extract file 'userdirs.tar.Z' and save in /usr [generally: c:\quartus\bin\cygwin\usr] Unmount /usr/lib [command from NiosII SDK Shell: 'umount /usr/lib'] Un-tar 'userdirs.tar.Z' [command from NiosII SDK Shell, issued from /usr: 'tar -xzf userdirs.tar.Z] Extract 'microtronix.bashrc' and rename as 'user.bashrc' in c:\altera\kits\nios2 [or append to existing 'user.bashrc' with command 'cat microtronix.bashrc >> user.bashrc'][/b] --- Quote End ---
