thanks to hippo again!
linux is running well on my custum cyclone ep1c6 board now.
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6936k/8192k RAM, 0k/0k ROM (646k kernel code, 492k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
unpack_to_rootfs 8bfc28+52579 check 0
populate_rootfs: unpack_to_rootfs return <NULL>
<6>Linux NoNET1.0 for Linux 2.6
NIOS serial driver version 0.0
ttyS0 (irq = 0) is a builtin NIOS UART
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
Freeing unused kernel memory: 368k freed (0x8b6000 - 0x911000)
BusyBox v1.1.0 (2006.01.16-08:41+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
# uname -a
uClinux (none) 2.6.11-uc0# 37 Mon Jan 16 16:57:42 CST 2006 nios2nommu unknown# top
top: not found# free
total used free shared buffers
Mem: 7328 5124 2204 0 0# ls -al
drwxr-xr-x 17 root root 0 Nov 29 17:00 .
drwxr-xr-x 17 root root 0 Nov 29 17:00 ..
drwxr-xr-x 2 default users 0 Nov 29 17:00 bin
drwxr-xr-x 6 default users 0 Nov 29 17:00 dev
drwxr-xr-x 4 default users 0 Nov 29 17:00 etc
drwxr-xr-x 3 default users 0 Nov 29 17:00 home
lrwxrwxrwx 1 default users 10 Nov 29 17:00 init -> /sbin/init
drwxr-xr-x 2 default users 0 Nov 29 17:00 lib
lrwxrwxrwx 1 default users 11 Nov 29 17:00 linuxrc -> bin/busybox
drwx------ 2 default users 0 Nov 29 17:00 lost+found
drwxr-xr-x 2 default users 0 Nov 29 17:00 mnt
drwxr-xr-x 2 default users 0 Nov 29 17:00 opt
dr-xr-xr-x 22 root root 0 Nov 29 17:00 proc
drwxr-xr-x 2 default users 0 Nov 29 17:00 root
drwxr-xr-x 2 default users 0 Nov 29 17:00 sbin
drwxr-xr-x 9 root root 0 Nov 29 17:00 sys
drwxrwxrwt 2 default users 0 Nov 29 17:00 tmp
drwxr-xr-x 5 default users 0 Nov 29 17:00 usr
drwxr-xr-x 3 default users 0 Nov 29 17:00 var# vi
as above ,linux cost memory more than other small rtos,for run real apps,8MB SDRAM is not enough,oh,I need a bigger one.
--- Quote Start ---
originally posted by hippo@Jan 16 2006, 03:57 AM
the snapshot dir are updated to 20060116 now.
i have updated the configs.zip, downloaded and tested with the buildroot-20060116, uclibc-20060116 and busybox-1.1.0. please check again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12214)
--- quote end ---
--- Quote End ---
