20 years agoKernel panic - not syncing: No init found.
Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: ...
20 years agoHi hootsmon,
The latest/svn uClibc/Buildroot has problem with Nios2. The buildroot has problem in elf2flt.ld and gcc patches. I am busy with other projects, and did not have time to get them fixed. 20060207 or 20070208 are the last known good snapshot. Busybox should be OK. If you're from China, they seem to block svn access.
