20 years agoKernel panic - not syncing: No init found.
Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: ...
20 years agoGreat!! I am happy with your success.
You can use "free" to find out the memory usage. You can try the following to reduce the memory usage. 1. The default busybox use more options than you will need. You can reduce the commands or features supported by busybox, only keep those you will use. cd ~/buildroot/build_nios2/busybox make menuconfig make cd ~/buildroot make 2. reduce the kernel, reduce unused driver and file system. cd ~/linux-2.6.x make ...... menuconfig make 3. remove unused files and nodes in rootfs/etc and rootfs/dev 4. you can delete files at run time when they are no longer in use. After carefully checking, the memory usage can be reduced by almost 50%.
