20 years agoKernel panic - not syncing: No init found.
Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: ...
20 years agothanks to hippo again!
linux is running well on my custum cyclone ep1c6 board now. uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6936k/8192k RAM, 0k/0k ROM (646k kernel code, 492k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) unpack_to_rootfs 8bfc28+52579 check 0 populate_rootfs: unpack_to_rootfs return <NULL> <6>Linux NoNET1.0 for Linux 2.6 NIOS serial driver version 0.0 ttyS0 (irq = 0) is a builtin NIOS UART io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered Freeing unused kernel memory: 368k freed (0x8b6000 - 0x911000) BusyBox v1.1.0 (2006.01.16-08:41+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # uname -a uClinux (none) 2.6.11-uc0# 37 Mon Jan 16 16:57:42 CST 2006 nios2nommu unknown# top top: not found# free total used free shared buffers Mem: 7328 5124 2204 0 0# ls -al drwxr-xr-x 17 root root 0 Nov 29 17:00 . drwxr-xr-x 17 root root 0 Nov 29 17:00 .. drwxr-xr-x 2 default users 0 Nov 29 17:00 bin drwxr-xr-x 6 default users 0 Nov 29 17:00 dev drwxr-xr-x 4 default users 0 Nov 29 17:00 etc drwxr-xr-x 3 default users 0 Nov 29 17:00 home lrwxrwxrwx 1 default users 10 Nov 29 17:00 init -> /sbin/init drwxr-xr-x 2 default users 0 Nov 29 17:00 lib lrwxrwxrwx 1 default users 11 Nov 29 17:00 linuxrc -> bin/busybox drwx------ 2 default users 0 Nov 29 17:00 lost+found drwxr-xr-x 2 default users 0 Nov 29 17:00 mnt drwxr-xr-x 2 default users 0 Nov 29 17:00 opt dr-xr-xr-x 22 root root 0 Nov 29 17:00 proc drwxr-xr-x 2 default users 0 Nov 29 17:00 root drwxr-xr-x 2 default users 0 Nov 29 17:00 sbin drwxr-xr-x 9 root root 0 Nov 29 17:00 sys drwxrwxrwt 2 default users 0 Nov 29 17:00 tmp drwxr-xr-x 5 default users 0 Nov 29 17:00 usr drwxr-xr-x 3 default users 0 Nov 29 17:00 var# vi as above ,linux cost memory more than other small rtos,for run real apps,8MB SDRAM is not enough,oh,I need a bigger one. --- Quote Start --- originally posted by hippo@Jan 16 2006, 03:57 AM the snapshot dir are updated to 20060116 now.i have updated the configs.zip, downloaded and tested with the buildroot-20060116, uclibc-20060116 and busybox-1.1.0. please check again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12214)
--- quote end ---
--- Quote End ---
