19 years agoJTAG UART dyslexia
Hi All,
I made a very small design and I got some problem with the JTAG UART terminal output. I compiled a simple "Hello world" and everything works fine excepted that JTAG UART is "dyslexic" : instead of "Hello World" I get "HHello World" in the JTAG UART console. Anybody can help ?6 Replies
--- Quote Start --- originally posted by bigboss25@Jan 28 2007, 02:17 PM hi all,i made a very small design and i got some problem with the jtag uart terminal output. i compiled a simple "hello world" and everything works fine excepted that jtag uart is "dyslexic" : instead of "hello world" i get "hhello world" in the jtag uart console.
anybody can help ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20966)
--- quote end ---
--- Quote End --- Well, I found the solution, but I don't know why it works ... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif Originally my master clock was 12 MHz, including JTAG UART. Then I changed only the JTAG UART input clock to 50 MHz... and it works . Strange. Is there something hard coded into JTAG UART which need a clock faster than 12 MHz ?
Yes.... The SOPC Builder system clock has to be greater than twice the maximum JTAG clock. Depending on what download cable you're using, you might see up to 10MHz on the JTAG clock.
- slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Feb 1 2007, 06:57 AM yes.... the sopc builder system clock has to be greater than twice the maximum jtag clock. depending on what download cable you're using, you might see up to 10mhz on the jtag clock.- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21112)
--- quote end ---
--- Quote End --- Brilliant http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif Works fine at 25 MHz now. Thx
--- quote end ---
--- Quote End --- Is there a way to slown down the JTAG clock (let's say downto 5MHz) via software option or does it only rely on my PC hardware? Thx.
--- Quote Start --- originally posted by bigboss25+feb 3 2007, 04:16 am--><div class='quotetop'>quote (bigboss25 @ feb 3 2007, 04:16 am)</div>--- quote start ---
<!--quotebegin-slacker@Feb 1 2007, 06:57 AM yes.... the sopc builder system clock has to be greater than twice the maximum jtag clock. depending on what download cable you're using, you might see up to 10mhz on the jtag clock.
- slacker
--- quote end ---
--- Quote End --- Is there a way to slown down the JTAG clock (let's say downto 5MHz) via software option or does it only rely on my PC hardware? Thx. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=21179)</div> [/b] --- Quote End --- Unfortunately no; I believe its actually a function of the download cable (USB Blaster, etc.). I could be wrong on this one, but I seem to remember that if you have access to an older cable (byteblaster, parallel port cable) this may have a slower Tck (JTAG clock) frequency.
TO_BE_DONE
