Issue after upgrading my Nios V SoC project from 23.1std to 24.1std
- 5 months ago
This issue was fixed.
There is no issue when all files (SOPCINFO, SOF, BSP, ELF) were generated by the same Quartus Prime version, 23.1std or 24.1std.
Use cases:
--> Using Nios V Command Shell 23.1std
- NO-issue: all files were generated with the same 23.1 or 24.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.
- FAIL: SOF files generated with 24.1 and SOPCINFO+BSP+ELF files generated with 23.1std.--> Using Nios V Command Shell 24.1std
- NO-issue: all files were generated with the same 24.1std or 23.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.I have run both Quartus Prime Standard versions 23.1 and 24.1 on the same computer using Windows 10. The DE0-Nano board is connected to the computer via a USB interface.
Domingo.
