Issue after upgrading my Nios V SoC project from 23.1std to 24.1std
- 1 year ago
This issue was fixed.
There is no issue when all files (SOPCINFO, SOF, BSP, ELF) were generated by the same Quartus Prime version, 23.1std or 24.1std.
Use cases:
--> Using Nios V Command Shell 23.1std
- NO-issue: all files were generated with the same 23.1 or 24.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.
- FAIL: SOF files generated with 24.1 and SOPCINFO+BSP+ELF files generated with 23.1std.--> Using Nios V Command Shell 24.1std
- NO-issue: all files were generated with the same 24.1std or 23.1 version.
- FAIL: SOF files generated with 23.1 and SOPCINFO+BSP+ELF files generated with 24.1std.I have run both Quartus Prime Standard versions 23.1 and 24.1 on the same computer using Windows 10. The DE0-Nano board is connected to the computer via a USB interface.
Domingo.
Hello Domingo
The problem seems to be that for some reason jtag is getting disconnected from the board.
We are trying to replicate the issue. We have a question: when you were testing the 24.1 sof file with the 24.1 Nios V Command shell, the BSP and ELF that you used were the ones generated with 23.1 or you regenerated them with 24.1?
Rolando
- Benitez__Domingo1 year ago
I tryed both options for generating BSP and ELF files: 23.1 std and 24.1 std.
In both cases, the output message is displayed only when the .sof file was obtained with 23.1std. When the .sof file was generated with 24.1std, the output message is not displayed for BSP and ELF files generated by both, 23.1std and 24.1std.
Domingo.
Use cases:
Domingo.
