himanshuvaria
3 years agoIs it possible to run NIOSV through SDRAM ?
Hello, I am developing a project where NIOS II needs to replaced with NIOSV processor. When my design was having NIOS II as CPU, I was running the software code through External SDRAM on the Cyclon...
KellyJialin_Goh
3 years agoHi,
Thank you for the information provided. Running NIOS V through external SDRAM should be possible.
Could you try to make the connection between "dbg_reset_out" to "ndm_reset_in" ? I will attach a screenshot on this qsys connection.
Also, could you try to use niosv-download command to try downloading elf to run the application and lowering the JTAG frequency to 6Mhz to check whether is it a RiscFree issue.
Thank you,
Kelly
KellyJialin_Goh
3 years agoHi,
Attached below is a screenshot of the qsys connection between "dbg_reset_out" to "ndm_reset_in" for your reference. You may connect it as of below to the NIOS V ndm_reset_in , external sdram and jtag's reset.
Thank you and looking forward to your feedback after trying the debugging steps.
Kelly
