hello hippo! hello hootsmon!
removed all dir. put patch command (with option -l) into buildscript.
let buildscript run like it did the first time.did not observe output of
buildscript nor put it to a file. here the last lines taken from commandline:
~/buildroot/build_nios2/root/usr/bin/uniq -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/unix2dos -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/unzip -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uptime -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uudecode -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uuencode -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/vlock -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/wc -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/wget -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/which -> ../../bin/busybox
make: Leaving directory `~/buildroot/build_nios2/busybox'# Just in case
chmod a+x ~/buildroot/build_nios2/root/usr/share/udhcpc/default.script
so everything seems to be in the right place now. is there a quick check
if it is working or should one simply proceed with hippo's thread?
next: how to keep the things up to date?
kind regards to all involved solving my questions
torsten
