21 years agoIncompatibilities with avalon sdram controller
my design consists of NIOS II (v5 SP1) with external SRAM, SDRAM and several peripherals, all connected through a single avalon tri state bus. During development a Micron 128 MBit (8MB x 16) SDRAM (MT48LC8M16A2) was used without any problem. Now at production line a ISSI device (IS42S16800A) is used, which constantly causes R/W verification errors. Modifying the phase shift of its clock didn't solve the problem.
- Has anybody made similar experiences with different SDRAMs at the 'Avalon SDRAM Controller' ? - Any suggestions ? Mike Added later: After further tests I discovered that the ISSI device with index 'B' has no problems.2 Replies
hi~
I have also experienced that problem. But, there was no solution as i know There was some difference with Nios II 5.0 Eval. Edition and Normal Edition(?) Eval. Edition was weaker(?) for SDRAM I was trying to modifying Phase shift, from -43 to -83 for -1 step. As i have modified my design, i should have modified phase shift value. how many trying? my suggestion is using LogicLock Region for SDRAM Controller. you find it, "Assignments" Menu in Quartus II - Altera_Forum
Meanwhile I've tested different 128Mbit-devices (8MB x 16) all with 50MHz Clock and a clock phase shift of -3ns to -6ns:
ISSI IS42S16800A-7TL <FAILED> ISSI IS42S16800B-7TL <OK> AMIC A43L3616V-7 <OK> MICRON MT48LC8M16A2-8BE <OK> SAMSUNG K4S281632F-UC75 <OK>
