how to use the floating point hardware in nios II custom instructions
hi
i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs.h># include "altera_avalon_pio_regs.h"# include "system.h" int main() { printf("Hello from Nios II!\n"); float a=3.1415926; float b=1.2578; float c=0; while(1) { IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0xf); c=a*b; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0x0); c=a-b; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0xf); c=b-a; IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE,0x0); } return 0; } in the code,i use pio to estimate the calc time roughly, firstly, i delete the floating point hardware, generate the hdl, compile the quartus project, build the software, then i find the calc time is 2.3us(the sys clk is 100M); then, i add the floating point hardware, and redo these steps, i find the calc time is still 2.3us i guess the nios did not use the floating point hardware, how can i fix this problem? is there any examples to show me how to use it? thanks!14 Replies
i check the system.h
and i find this: /* * Custom instruction macros * */ # define ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(n,A,B) __builtin_custom_inii(ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0_N+(n&ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0_N_MASK),(A),(B)) # define ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0_N 0xfc # define ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0_N_MASK ((1<<2)-1) i also tried c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(3,a,b); c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(1,a,b); c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(2,b,a); c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a) but the result is 0.0 - Altera_Forum
I assume you are using Floating Point Hardware 1 (not the 2). You will need to check your objdump to compare between the one with/out the FPH. If the custom instructions are properly inserted, you should see "custom" assembly codes appear in your objdump.
Floating point reference: https://www.altera.com/content/dam/altera-www/global/en_us/others/literature/ug/ug_fph2.pdf - Altera_Forum
Forgot to ask you, what optimization did you use for compiling the C code? The compiler seems to be trying to be smart by optimizing away the floating points operations.
okay, I think I know what is the problem, the system.h is passing the wrong argument for the builtin function. It supposed to be fnff instead of inii.
# define ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(n,A, __builtin_custom_fnff(ALT_CI_NIOS_CUSTOM_INSTR_FLO ATING_POINT_0_N+(n&ALT_CI_NIOS_CUSTOM_INSTR_FLOATI NG_POINT_0_N_MASK),(A),() If you update the system.h, it should remove the additional fixsfsi. Hopefully this works. - Altera_Forum
okey, i think the problem is the "hardware_fp_cust_inst_no_divider_present" option
if i uncheck it, the objdump file is c=a*b; 1082c4: e0fffc17 ldw r3,-16(fp) 1082c8: e0bffd17 ldw r2,-12(fp) 1082cc: 1885ff32 custom 252,r2,r3,r2 1082d0: e0bffe15 stw r2,-8(fp) c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); //* 108324: e13ffd17 ldw r4,-12(fp) 108328: 01084000 call 108400 <__fixsfsi> 10832c: 1021883a mov r16,r2 108330: e13ffc17 ldw r4,-16(fp) 108334: 01084000 call 108400 <__fixsfsi> 108338: 8085ff32 custom 252,r2,r16,r2 10833c: 1009883a mov r4,r2 108340: 01084780 call 108478 <__floatsisf> 108344: 1007883a mov r3,r2 108348: e0fffe15 stw r3,-8(fp) at this time, the system.h file is still "__builtin_custom_inii", it leads to c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); returns wrong value, like mikedsouze said . but that is not important, because the c=a*b works. - Altera_Forum
hi mikedsouze, thanks for replying
1.what is objdump? 2. i did use some optimization to reduce the code size, since there is no sdram in my test board: https://www.alteraforum.com/forum/attachment.php?attachmentid=11275 - Altera_Forum
1. <application_name>.objdump is a file found besides your <application_name>.elf file. It is a readable object file that gets translated from elf. It will shows you the exact code compiled.
To make sure that the floating point operations gets compiled, you should see something similar to below (for c=a*b operation): Without floating point hardware, software emulation: c=a*b; 2ac: d9000217 ldw r4,8(sp) 2b0: d9400117 ldw r5,4(sp) 2b4: 000031c0 call 31c <__mulsf3> 2b8: d8800015 stw r2,0(sp) With floating point hardware: c=a*b; 2ac: d8800217 ldw r2,8(sp) 2b0: d8c00117 ldw r3,4(sp) 2b4: 10c5ff32 custom 252,r2,r2,r3 2. do you know what is the optimization used? ie -O2 or -O0? - Altera_Forum
hi mikedsouze, thanks for your help.
i check the objdump file, i find it is a little like a assembly language file. when i add the floating point hardware in nios II, i use both c=a*b and c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,a,b); then i check the objdump file: c=a*b; 1082c4: e13ffc17 ldw r4,-16(fp) 1082c8: e17ffd17 ldw r5,-12(fp) 1082cc: 01084140 call 108414 <__mulsf3> 1082d0: 1007883a mov r3,r2 1082d4: e0fffe15 stw r3,-8(fp) c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); 1083d8: e13ffd17 ldw r4,-12(fp) 1083dc: 0108d340 call 108d34 <__fixsfsi> 1083e0: 1021883a mov r16,r2 1083e4: e13ffc17 ldw r4,-16(fp) 1083e8: 0108d340 call 108d34 <__fixsfsi> 1083ec: 8085ff32 custom 252,r2,r16,r2 1083f0: 1009883a mov r4,r2 1083f4: 0108dac0 call 108dac <__floatsisf> 1083f8: 1007883a mov r3,r2 1083fc: e0fffe15 stw r3,-8(fp) it looks like the floating point hardware will only be used when i use c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); but when run debug, the result of the c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a); is 0.0 - Altera_Forum
the optimization is -O0, no optization
That is very weird. With floating-point hardware inserted and BSP re-generated, c=b*a should directly infer "custom 252". Can you try to delete BSP and create a new one?
I tried c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a) ;, it gives me 0.0 as well. I am curious why there is the additional fixsfsi. It is trying to convert single precision to integer operation, which could mess the operation up. 2f0: 00003900 call 390 <__fixsfsi> 2f4: 9009883a mov r4,r18 2f8: 1023883a mov r17,r2 2fc: 00003900 call 390 <__fixsfsi> What version of Quartus are you using? I tried 14.1/15.0 works for me,
