10 years agohow to use the floating point hardware in nios II custom instructions
hi i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs....
10 years agoThat is very weird. With floating-point hardware inserted and BSP re-generated, c=b*a should directly infer "custom 252". Can you try to delete BSP and create a new one?
I tried c=ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(0,b,a) ;, it gives me 0.0 as well. I am curious why there is the additional fixsfsi. It is trying to convert single precision to integer operation, which could mess the operation up. 2f0: 00003900 call 390 <__fixsfsi> 2f4: 9009883a mov r4,r18 2f8: 1023883a mov r17,r2 2fc: 00003900 call 390 <__fixsfsi> What version of Quartus are you using? I tried 14.1/15.0 works for me,
