10 years agohow to use the floating point hardware in nios II custom instructions
hi i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs....
10 years agookay, I think I know what is the problem, the system.h is passing the wrong argument for the builtin function. It supposed to be fnff instead of inii.
# define ALT_CI_NIOS_CUSTOM_INSTR_FLOATING_POINT_0(n,A, __builtin_custom_fnff(ALT_CI_NIOS_CUSTOM_INSTR_FLO ATING_POINT_0_N+(n&ALT_CI_NIOS_CUSTOM_INSTR_FLOATI NG_POINT_0_N_MASK),(A),() If you update the system.h, it should remove the additional fixsfsi. Hopefully this works.
