10 years agohow to use the floating point hardware in nios II custom instructions
hi i want to compare the speed difference of floating point calc between custom instruction floating point and software. this is my code:# include <stdio.h># include <altera_avalon_pio_regs....
10 years agoI assume you are using Floating Point Hardware 1 (not the 2). You will need to check your objdump to compare between the one with/out the FPH. If the custom instructions are properly inserted, you should see "custom" assembly codes appear in your objdump.
Floating point reference: https://www.altera.com/content/dam/altera-www/global/en_us/others/literature/ug/ug_fph2.pdf
