How to use SDRAM IP core on Agilex 3?
I am testing my project on Atum Nios V starter kit from terasic, which bases on Agilex 3 (A3CZ135BB18AE7S) and SDRAM(IS42VM32160G-6BLI). my purpose is, realize a Nios V system with RTOS and use the SDRAM as the program ram of the RTOS.
My question: Agilex 3 is supported only by the higher version such as quartus pro 25.3, and the SDRAM ip is supported by previous old version quartus. do you have any solution that i can reuse the avalon interface SDRAM IP core on Agilex 3?
thanks.
- AvinashTh_Altera
Terasic has released, A Nios V processor-based design example demonstrating how to sequentially display bitmap image files from a Micro SD card on an HDMI monitor on github. This design includes SDRAM controller. Here the example design path is (github.com/terasic/Atum-A3-Nano/tree/rel/25.1/picture_viewer_1080p) This example design is targeted for Terasic Atum Nios V starter kit.
Please refer this design and modify as per your design requirement utilizing Nios V and SDRAM controller.
Please let me know if you have any further questions.
- Rainwang
Contributor
got it. thank you for the support, i am using the example for further evaluation.
- 3LionsCT
Terasic told me that the DE23-Lite board uses the same FPGA - SDRAM combination and there is an example there. I used it as a starting point for my Atum A3 board.
Now if only they would show us how to use the ethernet port!
