How to use SDRAM IP core on Agilex 3?
Terasic has released, A Nios V processor-based design example demonstrating how to sequentially display bitmap image files from a Micro SD card on an HDMI monitor on github. This design includes SDRAM controller. Here the example design path is (github.com/terasic/Atum-A3-Nano/tree/rel/25.1/picture_viewer_1080p) This example design is targeted for Terasic Atum Nios V starter kit.
Please refer this design and modify as per your design requirement utilizing Nios V and SDRAM controller.
Please let me know if you have any further questions.
got it. thank you for the support, i am using the example for further evaluation.
- 3LionsCT10 months ago
Terasic told me that the DE23-Lite board uses the same FPGA - SDRAM combination and there is an example there. I used it as a starting point for my Atum A3 board.
Now if only they would show us how to use the ethernet port!
- AvinashTh_Altera10 months ago
Ethernet example design for DE23-lite board is not yet released to public. Tentative plan is to get this example design by then end of Q4'2025. I will let you know once the example design is available. Till then stay tuned!.
Hi AvinashTH
Is there a plan to release an example for the Atum A3 board as that is the one I am using? Or will the DE23-lite example work with the Atum A3 Nano?
- Rainwang10 months ago
Contributor
Thank you for the information, i will check the examples for DE23-lite board. And I also plan to use the Ethernet interface in our design. it seems we have similar requirements.
Hi Rainwang,
I can confirm that the IP used for the DE23-lite board does work on the Atum A3. I just took the verilog files and used them to create a module in Platform designer. I was then able to read and write to the SDRAM from a RiscFree c program.
- BoonBengT_Altera8 months ago
Moderator
Dear Customer,
As clarification is being provided. Hence if there are no further inquiries during this period, Will allow the community to assist with any future follow-up questions.
Altera Technical Support
