19 years ago
how to use "msgget" in nios2 uclinx?
hi:
I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed.
After exec, but the return value is -1
I want to use cmd "IPCS" to check the ipc ID. but shell return: not found.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
How can I do? The same function "msgget" used in other uClinx os is OK.
Why failed in nios2 uClinux? Why the cmd "IPCS" not support nios2 linux?
Thanks a lot.
