20 years agohow to use "msgget" in nios2 uclinx?
hi: I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed. After exec, but the return value is -1 I want to use cmd "IPCS" to check the ipc ID. but shell return: ...
20 years agoThank you hippo.
I use make menuconfig and make in ~/buildroot/build_nios2/busybox dir. frist I enable " ipcs" second "make" but how can I update roofs? I use"make" in `/buildroot dir,but the busybox exec file is not the nios2 exec file
