20 years agohow to use "msgget" in nios2 uclinx?
hi: I use function ret = msgget(KEY_MQ_CORE, IPC_CREAT|0660); make successed. After exec, but the return value is -1 I want to use cmd "IPCS" to check the ipc ID. but shell return: ...
20 years ago --- Quote Start --- originally posted by hippo@May 11 2006, 02:10 PM for ipcs you can enable it in busybox under buildroot.
but i don't know if nios2 kernel support it correctly.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15279)
--- quote end ---
--- Quote End --- I enabled msg queue in kernel, run ipcs, # ipcs kernel not configured for shared memory kernel not configured for semaphores kernel not configured for message queues#
