20 years agoHow to specify 10Mbps and 100Mbps
Hi all,
How and where can I specify which LAN connection I want to use: 10Mbps or 100 Mbps; full duplex or half duplex? I am using NIOS II 5.1 'simple socket server example' on NIOS II 1S10ES Development kit. Sincerely, KVM.7 Replies
--- Quote Start --- originally posted by vizziee@May 22 2006, 11:56 AM hi all,how and where can i specify which lan connection i want to use: 10mbps or 100 mbps; full duplex or half duplex? i am using nios ii 5.1 'simple socket server example' on nios ii 1s10es development kit.
sincerely,
kvm.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15504)
--- quote end ---
--- Quote End --- There's some registers in the LAN91C111 that you'll have to set. Go to SMSC's site and download the datasheet for the chip. The driver that ship with the Nios dev kit sets it to auto-negotiate the speed, so just search for where it does that and change it to use whatever speed you want.
--- Quote Start --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15504)</div> --- Quote End --- There's some registers in the LAN91C111 that you'll have to set. Go to SMSC's site and download the datasheet for the chip. The driver that ship with the Nios dev kit sets it to auto-negotiate the speed, so just search for where it does that and change it to use whatever speed you want. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15513)</div> --- Quote End --- Thanx a lot. But can u tell me by default, what line (mbps and duplex method) is used in simple_socket-server example? Sincerely, - Altera_Forum
It's not just in the example or even, really, a part of the example. It's in the driver code for the 91c111. <lan91c11_comp_dir>/UCOSII/src/altera_avalon_lan91c111.c
- slacker - Altera_Forum
By default the driver allows the lan91c111 chip to auto-negotiate its capabilities with whatever it is connected to.
--dalon - Altera_Forum
--- Quote Start --- originally posted by slacker@May 23 2006, 10:00 AM it's not just in the example or even, really, a part of the example. it's in the driver code for the 91c111. <lan91c11_comp_dir>/ucosii/src/altera_avalon_lan91c111.c- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15535)
--- quote end ---
--- Quote End --- Thanks slacker. In which file and what change should I make to force the connection for 10Mbps Full Duplex mode (as I observed my custom board is malfunctioning at 100Mbps mode). Sincerely,
Take a look at the existing code (which sets the PHY to auto negotiate) and modify it. I've already mentioned which file it's in... <components>/altera_avalon_lan91c111/UCOSII/src/altera_avalon_lan91c111.c
There's a section which starts with the comment
You need to modify the code, in this section, to set the PHY to 10/Full. It appears that all of the masks that you'll need to do this are already provided...in the <components>/altera_avalon_lan91c111/inc/altera_avalon_lan91c111.h header file. Best of luck! - slacker/* Start the Auto Negotiation process */ /* Try to negotiate, we have a go at this five times if it fails */ - Altera_Forum
--- Quote Start --- originally posted by slacker@Jun 28 2006, 10:28 AM take a look at the existing code (which sets the phy to auto negotiate) and modify it. i've already mentioned which file it's in... <components>/altera_avalon_lan91c111/ucosii/src/altera_avalon_lan91c111.cthere's a section which starts with the comment
/* start the auto negotiation process */ /* try to negotiate, we have a go at this five times if it fails */you need to modify the code, in this section, to set the phy to 10/full. it appears that all of the masks that you'll need to do this are already provided...in the <components>/altera_avalon_lan91c111/inc/altera_avalon_lan91c111.h header file.
best of luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16475)</div> --- Quote End --- Thanks slacker. I changed the register mask (PHY CONTROL register) in the header file altera_avalon_lan91c111_regs.h and set it for 10Mbps FDX mode. But it didn't work and gave an error 'Failure in initialiazing lwip_devices-init' while running the rogram. Can you give a detailed answer how I can set the speed? Sincerely,
